I've had a Brandt & currenting use the Scancoin 303 - they both will work with wet coins but you have to baby them a bit. I've gone to a heat gun instead of a hair blow dryer. It heats up the coins and they dry a lot better. I also start by putting them in a bucket and set the heat gun blowing down so the coins get nice & hot and dry themselves. I've use a old Klopp coin holder on top of a bucket where I point the dryer on them and dry them as much as possible, then they go into the Scancoin 303. If you point the dryer at the point the coins go into the sorter of the Scancoin, it will pretty much keep the mechanics dry and will be able to keep counting. Hope this makes sense - I can send you a pic if it's not clear.
