I just switched over to KRs ultra concentrated triple foam from my distributors triple foam on my In-Bay Automatics. The only thing I didn't like from my distributors triple foam was that it would grow a thick film inside the mixing tanks and foamers. I made the switch to save some money especially that KR said it is ultra concentrated and has a much higher dilution ratio than what I was using. The biggest problem is that the show isn't there. The KRs triple foam comes out more bubblie with larger bubbles than my previous triple foam which had small tiny bubbles more like shaving cream and with a nicer scent.
I have fooled around with its adjustments of air and chemical and still can not get the show. If I use a much stronger dilution ratio it may give it a better show or it may not and my cost per car will probably go back to where I was before. So my question is, What triple foam have you found that works the best for you? Please let me know if it is a Polish, Detergent, or Low pH.
