Ls brothers
I just replaced the new water pump but still have problems to pumping the water. I need to prime water all the time to let it pump. Anyone know what’s wrong with it? How can I do? Thanks for any advice !
Replaced the new pump same as before. It’s pumping but just need to filling the water to PVC pipe let it running.Gotta get a newer, Larger pump, ASAP, no.
There are a lot of different types of pumps. What kind of pump are you using? What are you using it for?I just replaced the new water pump but still have problems to pumping the water. I need to prime water all the time to let it pump. Anyone know what’s wrong with it? How can I do? Thanks for any advice !
This pump for pumping the waste water for pits.There are a lot of different types of pumps. What kind of pump are you using? What are you using it for?
This pump. For pumping the waste water for pits.There are a lot of different types of pumps. What kind of pump are you using? What are you using it for?
I didn’t see any check valve around the pump. Do I need to check outside anywhere?thanks so much for you help.How far does the pump have to draw the water? could be the pump housing runs out of water before being resupplied, maybe a check valve to keep it from back draining when it shuts off.
Do you think where should I add a check valve?thanks so much for you help.I'm not a plumber but it seems to me if the water can settle back into the pit once the pump sends what water wat trapped in the impeller housing, air would replace it and the pump would loose its prime. a check valve designed for the size pip that feeds your pump, would prevent the water from backflowing into the pit and the pump would stay primed.
Here is the picture,can you please show me where can I add?thanks so much for you help.Add the check valve on the output side.
The pump just like when I bought the car wash 4 years ago but it started have problems around 2 years ago. And I just replaced the new pump 1 month ago but still need to filling the water all the time to make it pumping water.thanks so much for you help.You need to add a foot valve (check valve) on the suction side of the pump, at the end of the suction pipe. The problem you’re going to have is there is a lot of debris in the pit water and it will foul the foot valve in no time. Where are you pumping this water to? Was there a pump there before this pump was installed?
Also,Check Valve (to prevent the water in the pipe from flowing away from the pump inlet once the pump is primed; to keep the pump primed)
Where does this pump pump the water, to the sewer, to the roof, to the storm drain, parking lot wash down?The pump just like when I bought the car wash 4 years ago but it started have problems around 2 years ago. And I just replaced the new pump 1 month ago but still need to filling the water all the time to make it pumping water.thanks so much for you help.
