- Joined
- Aug 30, 2007
- Messages
- 4,296
- Reaction score
- 1,188
- Points
- 113
- Location
- SW Indiana melon fields.
I have an EVD-3 standalone fragrance machine whose FragraMatics branded IDX acceptor took a crap on me. The decal is faded, but I think it says MA-809. I went to replace it with a standard MA-800 and discovered that the original acceptor had only one coin switch wire (red/green) while the new one has two. After a call to Jim Gosnell I wired it with the extra wire piggybacked to the black wire. This did not work. The coins were accepted, but the machine wouldn't come on. After a lot of head scratching and a couple more calls to Jim he instructed me to piggyback that extra wire to the yellow instead of the black. This worked, but a quarter will turn the machine on and a token or dollar will buy 4 times what the timer (GS-7) is programmed for. I had it programmed at 40 seconds and a $1 start. Watching the green light on the acceptor seems to verify it is working right. It blinks once for a quarter and 4 times for a dollar or token. Jim is at a loss as to what is going on. I ended up setting the timer for 15 coins to start at 3 seconds per coin. It works this way, but it's kind of a screwy way to do things. Has anyone else ever run into this?
