Window Residue - how to clean windows
tw1012
Austin
I have been just using windex and i am getting an residue on the inside of the windshield when we clean a car. It really shows up in the sun and im sure my customers have noticed it. I'm sure there is a better product and a way to avoid this.
thanks,
Trevor
Bubbles Galore
Michigan
I've wrestled with this for years now and found this was the best solution for me. I use 2 microfiber towels whenever I do windows. 1 to clean the window with the solution and 1 to buff the window crystal clear. As long as I'm not in the sun, I can get windows sparkling clean.
I have tried multiple cleaners with the 2 towel method and have always seen the same results...crystal clear. Try it out and let me know if it works for you.
My windows procedure:
1. Kleen Rite Glass Cleaner concentrate applied w/micro fiber towel.
2. Wipe w/surgical towel.
3. mist with clear water and wipe again with fresh surgical towel
I recently added the third step because windows are very difficult for us to get as good as I like them (which is perfect).
Use towels that are dedicated to cleaning windows only. They should be washed seperatly and not with towels that you use for other things.
Yes good point Soapy. I wash all my windo towels separate from all else.
