WW 2.0 triple shine coating comes out stronger on one side than the other.
Rainway
Alaska
Coleman has a new foam generator that is easy to remove and clean out. It loos like almost a Mr Foamer generator. Its a nice upgrade on a new unit but you it really shouldn't be something you have to do that often so I doubt I will replace my existing ones.
This sounded great sometimes our trip foam gives us headaches we’ve had to open our foam generator lots of times. I ordered a new foam generator, I got the same PVC style that’s on my 12 year old unit.
maybe a mr foamer is a way to go if I can retrofit one...
Rainway
Alaska
UPDATE:
Ok the problem is solved. the issue is the fact that the driver side has a 180 degree turn. So added a valve (as per pic) to adjust the flow. So now you can adjust how much you want to come from which side.
Something odd about old attachments they’re totally random pics now. Anyway you could post a picture of your setup for adjusting between sides?
