Since you are running 2 heaters, you'll get more flow and pressure with the 2400-45-3P than I'm getting with my (2) 013's....Did you check amperage on the 2400 series pump? Its 3.6a at 115v. Make sure your relays and aquastats handle the extra load. The 013's are only 2.0a. You'd think almost double the amps, you'd get double the volume and pressure!? LOL.....Probably like a boat, double the horse power and get a few more mph!
I'm trying to finalize the exact location of components in each loop. After looking at many diagrams it isn't very clear to me. Even though I have seen a few online diagrams that contradict this, I will call the boiler loop the primary and the floor tubing loop the secondary. Maybe there is a little flexibility on the exact location of a few of these components. I'll list where I think they go and you or others can agree or point me the correct way if not:
Primary loop:
The two pumps plumbed inline feed the cold side heater inlets.
Shut off valves on either side of the pump assembly
Pressure gauge between pumps and heaters
Temp gauge on hot side outlet going to the secondary loop
Secondary loop:
Single pump plumbed on hot outlet side of closely fitted tees that join the loops feeding outgoing floor tubing manifolds
Air eliminator plumbed between the pump and the closely fitted tees and boiler drains on each side for fill and purge (I have also seen this located on the primary loop)
Expansion tank plumbed into the bottom of the air separator if I have the space for that large assembly. Otherwise, I may plumb it elsewhere near the separator.
Mesh strainer between return cold line from manifolds and closely fitted tees (I have seen this in many different locations)
Temp gauge on the outgoing hot line to manifolds (not sure if it matters if it is before the pump or after)
Temp gauge on the return line from floor manifolds to mesh strainer/closely fitted tees
Primary pump temp control probe clamped to return line and insulated
Pressure gauge. Should this go on the hot supply going to the manifolds or cold return? I think it might show a little higher pressure on the outgoing side.
30 PSI pressure relief valve (^probably next to the system pressure gauge^)
I'm trying to keep as many components off the primary loop as reasonably possible. Using two heaters already complicates things with those parallel circuits going to each.
Other than isolating the pumps for maintenance where else should I plumb shut off valves? The air separator needs vertical orientation and the pump motor shafts need horizontal orientation with the electrical junction boxes on top. Are there any other components that orientation or gravity may play in?
