lighthousecarwash
So I've posted a couple threads about tankless boilers for my floor heat and tankless water heaters for my auto, but I am still not sure I know which route to take. First of all, the floor heat is going to be on hold as I think it's getting too close to winter to start tinkering with floor heat. Here is my issue with the hot water and what my opinions are. Tell me if I'm on track or way off base.
1. I want to install a dedicated tankless water heater for my new Razor. I think this will be an easy fit because I can mount one of these units on the wall about 2 feet away from the pumping station. This should provide almost instant hot water to the auto. I'm looking at an AO Smith 540 (199,000 btu)unit that I believe is actually a Takagi. I have the option of adding a second Razor if this one gets too busy. I would put the second pumping station in the same vicinity of the tankless water heater. I'm hoping that by doing this, I can utilize the same tankless unit to feed both autos as it's only the solutions that will be hot and should not require that much GPM. I'm hoping for solutions around 120-130 degrees. The whole gray area with these things are the temperature rise and the GPM. With my current system with a boiler and 75 gal holding tank, none of that is a problem. I have ample reserve of hot water as the boiler catches up. So is a 6.6-10 GPM system enough to raise the temperature 70-80 degrees and not run out of water supply. If the demand is too much for the WH to supply that much of a temperature rise, then do I just get lower temperature water, or do I get lesser flow and still the same temp of water. I don't want to starve any pumps. What say you?
2. My self serve bays all operate out of a Magic Wand pump stand. This stand has a mixing tank for all the soap/wax solutions, and a clean hot water tank that feeds to pumps. Now my issue with this system is that the mixing tanks cool down over night and take a little bit of time to heat up once hot water starts flowing into them. With my 75 gal holding tank, there is still a delay in hot water getting to the mixing tanks. I've been told that if I eliminate my boiler, that I still need to have the 75 gal holding tank with the circulation pump to keep it heated. Why? If I place 2 of the above mentioned units, only a few feet from the mixing stand, then I should be achieving the same results. I would think a few seconds of flow and we would have instant hot water. Since I have the mixing tank with clear hot water, I shouldn't have an issue with starving the pumps because I would have 10-15 gals of hot water in that tank as a buffer. I have not done any calculations, but I think 2 units linked together should be able to support the 4 self serve bays. They will only be using hot water for the low pressure functions and the HP wax. I also was told we could go to a 6 gal holding tank and eliminate the 75 gal tank. That way we would have an instant reserve of 6 gals to get started when the mixing tank calls for water. But this would require the need for circulation pumps again, and heating that tank whenever it dropped below 115 degrees. I know I could use a timer and probably make that more efficient, but I don't think I even need it. Ok, help me out people. What do you use and how does it work for you?
In need of help!
Lighthouse.
In need of help!
Lighthouse.
