cleaning up mud
that's why I bought a battery powered dremil tool to grind the knob off.
A little off subject to this thread.... I have been having what seems to be a major problem with my 8 position Electroswitch actually seizing up. The back side of the switch is fine, it is where the rotary knob connects to the switch. There is some grease from the factory that seems to collect dirt and soap that causes the problem. Once I take off this portion of the switch, the internals spin fine. I have been using this brand switch for over 25 years and never had this problem until about four years ago. The only change I made was removing my heat tape from inside the coin box. The switches give me no indication that they are going to seize right up to the point of seizing. I have replaced at least 20 different switches over the past 4 years. Before this, I replaced only 3 or 4 over 20 years. Is there a manufacturing problem, or do you think it could actually have something to do with the heat tape removal?
I dont mess with taking them off, I use the same time-honored technique as many of us use for replacing vac brushes. Crush it off with channel-lock pliers and replace it with a new one.
Etowah Valley sells a retainer nut with a rubber seal that should work better than o-rings.I'm wondering, has anybody ever experimented with putting a few 1/4" I.D. O-rings between the knob and housing to help keep water out? Its not a huge deal to change a switch out, just trying to come up with options to make them last longer. I had a switch seize once and it spun in the face plate that wadded all the wires up inside the box. Could have been a real mess if I wasn't there when it happened.
