Just about to order some salt. Ouch- I remember when this stuff was three bucks a bag or less. Current pricing in my area is 6.47 for 40 lbs of diamond crystal. Mortons is not even locally available. I can order Morton's from Ace with a one week lead time for 6.99/bag.
I’m new so this might be a dumb question. What about using a salt free water softener system? Do they work w car washes?In your opinion what is the best Salt brand out there to use for Water Softeners? I'm currently using Diamond Crystal Solar Salt and my distributor is discontinuing his salt delivery business so I'm seeing what to switch to or stay the course and have a pallet drop-shipped which is probably going to be outrageously priced.
What kind of Carwash Equipment are Using and what type of Softeners do you have?Coach,
I suspect you’re softener was improperly set up resulting in overdosing and or too frequent regeneration.
A cubic foot of standard resin can be regenerated to 75% of its capacity with 6 pounds of salt. The remaining 25% requires nearly 12 more pounds of salt. Its extremely inefficient to regenerate a softener to 100% capacity. Some fine mesh resins can achieve 75% capacity with 4 pounds per cu ft.
Nearly every system I’ve serviced is grossly over salting...probably due to installer negligence, inexperience, or profit motive, i.e. they work for a company that sells softener salt. No names mentioned but...it starts with C.
Unless your raw water is so hard you get bruises when you shower, there’s no way a “real slow wash” should ever use 80 to 120 lbs of salt per week.
Just sayin.
Can you not repair it? I've worked on a couple of mine. They are pretty simple. Who's going to know that you put a kit in it?my RPZ valve is gushing water down the drain and I can't replace it myself.
