Danfoss Drives
Is this the newer model you have: Danfoss 132F0010 ? I replaced all the 176fs with these and have had no issues.
Yes
Unable to get any help on programming or wiring
From danfoss or coleman.
Coleman suggest using yaskawa from them at 3 to 4 times the cost.
176f are easy to install and program
Washvac
Do you have information on wiring and programming on the 132F0010 vs the 176F danfoss?
If possible I would like get it so I can change mine , as I have 2 new dansoss drives in eq. room now.
Thanks for any help .
Tom Thumb
I will grab the info next time I am at that wash. It will be mid to end of week. I have to look at wire and try to remember what was different. The programming was fairly easy; I just went through the manual checking each parameter--man there is a mess of them. The only issue I had was getting the slow speed on the drive motors. But I finally found it by playing around. PM me your e-mail, and I will send you what I have.
I am also trying to switch over to the newer Danfoss drives (132F0010). Would anyone be willing to share the wiring and programming information for WW1?
Phillip
