Fleck 9500 water softener issues
Buckeye hydro here has a softener company and is nice enough to give us a little tech support, you may want to give him a chance to quote.
Since the 9000, 9100, and the 7000 Fleck valves are mentioned ... I am curious to know if the Clack valves run over $500 not including labor.
Last spring we finally solved that same problem of leaking into the brine tank continuously. We opted +$$$ to replace any part that could cause the problem on two Fleck softeners. So far so good but this thread has us thinking about the Clack .... if it happens again. Leaving it not corrected for too long caused us to spend hundreds of dollars on wasted salt pellets ... our bad!
Welcome to the unpleasant world of Fleck valve maintenance. Flecks work fine when they are new, but maintenance is like working on an engineering dinosaur.
Did you replace all three seals/spacer assemblies?
Did you replace all the pistons?
When you replaced the seals/spacers and pistons did you have the valve off the tank and have the stack oriented vertically?
Are you up for replacing that valve instead of struggling with the maintenance? We try to replace these when customer allow - there is a much better, American-made valve option available (Clack).
Russ
What does a clack that is equivalent to the 9500 run?
Making assumptions about a bunch of variables, here's some comparative info with ballpark $.
The old Fleck 9500 is a 1.5" brass body, metered, twin valve. The cost of that valve and associated parts (not including tanks, media, etc) is about $3200.
An assembly of Clack parts (two brass 1.5" valves, a MAV, and a stainless meter) is about $2850. Lower costs are available if we substitute a composite, rather than brass valve body and meter.
Russ
The plastic spacers are exactly the same dimensions as the brass spacers. The difference is the brass spacers are made for hot water applications. They do have the added advantage of not being susceptible to chlorine degradation like the plastic ones, but if not service regularly they will fuse to the inside of the brass valve body and turn your control valve into a paper weight. If you're leaking to drain during standby it's definitely caused by something in the upper bore. Either you didn't seat a seal/spacer correctly or there is some debris (probably from an old seal) still inside the bore on one of the valve seats. If you're leaking to brine tank, that's caused by a bad brine valve and has nothing to do with seals/spacers. I have been working with Fleck valves for many years and they don't bother me to work on, but Buckeye is right, Clack valves are much more reliable and cheaper to maintain. That being said, they still make all the Fleck parts, even for really old control valves. If you're not ready to upgrade to Clack, you just need to find a qualified Fleck tech (which won't be easy).
Thank you. One theory I am exploring is that the upper piston might not have the correct plunger length causing an incorrect position. I am hoping that might be it. A out of spec piston seems plausible since it’s hard to believe 2 valve bodies would be bad. One of them is essentially nos.
As of about 3 weeks ago, Fleck sent out a message to their distributors identifying a large number of parts they will no longer be making. I can get more info/specifics on this if people are interested.
Russ
If you have the right part number piston I would say it is highly unlikely that there is anything wrong with it (unless the teflon coating is damaged).
Finally I figured this riddle out!!! I was sold the wrong upper piston. The commercial 9500 has a shorter shaft than the residential model. Shout out to Clearwater in Clearlake Michigan for giving me this idea and I was able to troubleshoot it. About 8mm difference in shaft length made the difference. The 2 shafts are pictured below.
IT WORKS!!! Cue the 2001 theme song…
View attachment 12837View attachment 12836
Which part numbers are you dealing with? The Fleck 9500 is an 1-1/2" control valve and does not have a residential model. You might have a 9000 or a 9100 which are both 1" models. If you do have a 9500 the part you need is 60108-02
I’m not sure yet on part numbers. Will post when I learn more. Apparently the concept of a poke yoke has not been implemented in this industry. A wrong part should not be installable…
The part numbers should be printed on the plastic packages the pistons came in. A wrong part should not be installable? Try and tell Fleck that! Wait until you get into the HWBP and NHWBP pistons.
the wrong parts should not be installable but in fact they were. Slight difference in shaft length made it very hard to detect. A poke yoke would have made the pistons different shapes and colors. Bags can be mislabeled or packed incorrectly.
I don't disagree with you but that is how Fleck has been doing things for 80 years. I really don't mind because Fleck valves are what I cut my teeth on and now no one else in my area knows them like I do. They for sure can be a b**ch sometimes but Clack valves are so easy it's almost like cheating sometimes. And...wtf is a poke yoke?
lol - I’m too much of a manufacturing guy. Basically an error proofing feature in a design or part. Here’s a good link to the topic.
Next challenge is the timer - it has a timer pictured - believe it’s a 3200ET. What newer units would be compatible with the 9500 valve and power head?
