James.Ireland
Hi all,
I'm thinking of changing up the high pressure soap and high pressure wax setup at my 2 bay self serve wash. When I put the wash back in service I replaced the old flow meters with the Dwyer units in the picture below. These pretty much all started to leak within about the first month. Anyone have good luck with flow meters? If so what brand do you use?
Right now I'm mixing soap and wax as there was a good stock of the product when I re-opened the wash and the setup seemed to work fine if I measured the chemical out reasonably well.
I'm hoping to get a couple HydroMinders setup so I have less to worry about. Also I'm hoping to get rid of the metering valves as they sometimes seem to gunk up and stop the flow of soap and wax. Does that sound like a bad idea to anyone?
