I'm running a very busy 6-bay car wash off one line that size, four low pressure systems with Flojets. It's enough.You are starving it. Your flojet wants to drink from the black hose which is connected to a PVC pipe; and that same PVC pipe also feeds the generators. The pipe is being fed by a straw. How can the FloJet get enough air from a pipe that is not being fed enough air to supply it and at the same time supply the generators?
