Foam Brush Help
mcarter1990
I have a couple questions about my foam brush setup.
See picture:
What air pressure do I set the air at? Currently at 60 psi
My foam doesn't look foamy it is more liquid than foam.
What do I need to do?
You might need to increase the strength of the chemical. 60 PSI is way too high for the air. I run it 15-20 PSI.
mcarter1990
I bought the soap from Carwash Superstore.
It feeds into a 55 gal drum ( Mixes ) the mixture is 200/1
To me 200:1 seems too weak. Is the 60 psi on the air coming into the Flojet or the air injection?
mcarter1990
Yes. We were there today and changed out a few things and still getting more liquid than foam.
Did you try adding some product to the tank to see if it's too weak?
Can you post a video of it running? A picture doesn't help much.
mcarter1990
I did not today but it wasn't much different than the picture I posted earlier.
IMcarwash
See picture:
Do you have a foam generator in line?
Make your product stronger. I had same issue, & received the same advice on here. Tried it & that worked.
mcarter1990
I purchase a new Foam generators and will be installing those on Saturday. I will increase the product. Thanks for the tip.
mcarter1990
Weekly follow up: Still have more liquid than foam. Ideas?
Rfreeman
Ft. Worth
Is this just in a single bay or all your bays at the wash look like this?
