Guns, Tips, and Pumps
Noob
TN
The only pump that rattles is the top left. Can MEP or IB or anyone else post a picture of how a pump should be correctly plumbed?
Have you tried reducing the pressure or changing the regulator?
Noob
TN
Not yet. Will try that soon and let you know what happens. I appreciate the help guys. I’m still new to the industry and still learning. I have done all the repair and maintenance work myself. Some things I still don’t understand all the ins and outs of. Your help is greatly appreciated.
Noob
TN
Looks like I’ll be changing out the regulator on the pump. I know you guys had mentioned that the water was very turbulent going through the pump due to the way it was plumbed. Can you give me some recommendations on how to improve that? I was under the assumption that a pump could basically be plumbed only 1 way?
Noob
TN
The way my pumps are set up now the water enters the at the bottom left exits at the bottom right then goes through the regulator and enters the top left and out the top right. Is that correct?
No, that's not correct. The water from the tank enters bottom left. HP water exits top right into that Home Depot store's worth of fittings and heads out to the bay. The water not needed to maintain the desired pressure/volume exits top left, through the regulator and out that smaller blue hose that is connected to bottom right. The bottom holes are just connection points to the same place. If you took the fittings out you would see that it's just a straight through hole, same as the top. That's why I don't like the blue hoses entering opposite one another. I may be making too much of it and maybe the extra turbulence won't amount to a hill of beans.
