i recently changed the timer on my jim coleman combo vacs to dixmor 6s but I have an issue in the past the customer could only select either vacuum or fragrance but after the timer change they are able to switch back and forth from vacuum to fragrance is time is remaining . did I miss some programming on the timer I want the customer to be able to select vac or frag and not be able to switch over until the cycle times out
