I have a Jim Coleman shampoo/vac that only gives me the option to vacuum. The timer used to display "insert $1 for vac or insert $2.50 for shampoo", but now you only get the option to vacuum. It is also hooked up to the swipenclean system. I have tried replacing the timer, pbc and keypad all with no luck. I even took all 3 out of another shampoo/vac that I have and put them in the defective one and still only got the vac option. I spoke to Jim Coleman and they insist that the only things that would control that function would be mainly the timer then maybe the pbc or keypad, so I am not sure what else to try. The only other time it used to behave like this is when it would run out of shampoo, the red light would come on and then you would only get the vac option until you refilled it then reset the machine. I am out of ideas. Any thoughts?
Thanks.
Thanks.
