LED exit timer for dryer
I think maybe Dixmor fix's them since it's a Dixmor product. Call Nick at Dixmor
When you send it to Dixmor take it out of the case and pack it well.
bigjws
Houston
Definitely Dixmor...they’ve repaired a few for me quickly and thoroughly. Just send in the board and description of the problem. If the numbers are getting dim, they can replace the LEDs also
Send it with your name, phone number, and return address with a description of the problem. You don't need to call them. They'll call you for a CC number when it's ready to ship back.
Dixmor Enterprises
5755 S. Gallup St
Littleton, CO 80120
303-794-0597
Turnaround is generally very fast, repair costs are usually very low.
Per advice from some operators on here, we took ours out. Smart move.
Kramerwv
WV
Dixmor Enterprises
5755 S. Gallup St
Littleton, CO 80120
303-794-0597
Thanks - good info!
fastlx
Georgia
I would imagine they took it ( the timer display) out so that customers don't take full advantage of the time. and just pull through....The dryers pull ALOT OF AMPS.= save a lot of $$ on the power bill and speeds the wash up for the next customer?
wyatt
northwest
I sent mine in a year and a half ago because some of the sections had burnt out. Dixmor repaired them and sent them back quickly which was great!
However, now I'm noticing that some letter sections are going bad again already.. I've never had a Dixmor screen burn out but the dryer one sure seems to.
