I have about a 30 year old (4) bay Mark VII pump stand. For its age, its remarkebly trouble free. In the past (2) years, I've only had to replace (2) FB solenoids. Most of the solenoids look to be original. I've done other maintenence to the stand, but changing out a solenoid leaves a lot to be desired...
I am putting together a parts list to change the FB and Pre-soak solenoids to the Kip Manifold style solenoids. I will mount them at the end of the pump stand on the wall which will make them much easier to work on (for lots of reasons). These are fed with Flojets, so converting the FB and Pre-Soak won't be an issue...
My question is, has anybody ever moved the Wax and Soap solenoids since they are vaccum fed to the pump? If I add two more (4) solenoid manifolds on the wall at the end of the pump stand, I'm wondering if there will be any issues drawing wax or soap into the HP pump...I could run 3/8 poly from the solenoids over to the flow meters...The farthest the soap or wax would have to go from the solenoid to the flow meters is about 8'. I haven't ever had a Soap or Wax solenoid fail. But I think you can see from the picture how much a pain it would be to change one out. Changing the FB or Pre-Soak solenoids is bad enough...
In case your wondering....Getting a new pump stand is out of the question!
