Car_Wash_Guy
I've read all the threads here on FB. I want to make mine like IIRC Earl Weis' shaving cream!
Using Blendco Pink Foam Brush with Blendco metering ( would like to change over to traditional tips)
Water is good - <1 grain of hardness.
Pressure is @ 30psi Product/40psi Air
3/8" poly lines to above bay where it is T'd and then passed through a foamer and down to bay.
Running Fluid-O-Tech pumps
I've tried multiple combinations of psi ratios. Equal, higher, lower, etc.
I've tried cleaning & adding more "scrungies" for more/better foam.
I've tried adding 16oz of additional concentrate to the mixing tank.
I've verified that air is indeed passing through solenoid&manifold and out to bay.
Pic of mixing tank
Video of performance:
https://youtu.be/9GsVRQT88do
Thanks for any advice
Pic of mixing tank
