pump/motor mounting fabricator
1carwash1
east japip
Can someone recommend a fabricator/welder who can make a pump/motor mounting plate out of stainless steel? I have the dimensions and no holes need to be drilled. Can't be that hard! IMG_6859.JPG IMG_6860.JPG
HeyVern
any sheet metal shop should be able to make one.
1carwash1
east japip
You would think so....
you would think so......today I requested a quote on three 1/4 stainless sheets, 28 x 20, one quote was approximately $450.00 and the other was over $800.00. Is stainless really that high? Yikes!!!
Yes.
You don't need 1/4". 12 gauge should be sufficient, but it might need a piece of angle along the length on the underside to keep it from flexing.
eckert16
...CA VA OH PA
If Timmb doesnt work out, you could Shop your local fabricators. Not that difficult, especially if you already have the item on hand that the shop can use it as reference. Just be aware, if you want it “tomorrow” you will pay for that speed. If you are flexible, then they can work it into a larger product, you can get a substantial discount for not needing it in a hurry.
