R.O. help
rossallen768
im working on a colman sparkle system am lost. so to start with end caps of membrane cans were leaking a little o i thought it was a good time to change membranes. shut the system down changed out membranes fired it back up and all it will do is reject 100% of the water. im at a loss an have no info on the system
It's probably flushing. Give it about 15 minutes, the flush solenoid should close and the pressure will come up.
Buckeye Hydro
If the caps on your RO membrane housing(s) are leaking - you need to at least lube, or replace the orings on the cap. Changing the membrane won't address the leak.
Russ
Where does that say he thought it would stop the leak?
rossallen768
I know replacing the membrane will not stop the cap o ring leak I ment it as "I'm going to be in there any way might as well change the membrane.
