Random Hydrominder Issues, any tips or tricks?
Where are you guys getting your water, out of a farm pond full of cattle? I never had clogged screens, with the exception of resin from a malfunctioning water softener. Are you guys using iron/steel fittings? I never used anything but brass, PVC, or stainless and didn't have any issues at all.
The one time I had issues was getting clogged with some soft green stuff out of the water heater.
I’m a little leery of using the plastic strainers on the water supply. I’ve seen them develop stress cracks and have the bowl blow off. We use a brass DEMA “Y” strainer https://www.kleen-ritecorp.com/p-1653-dema-strainer-y-type-line-strainer-1-2.aspx and clean it out about every 6 months, there isn’t much of anything inside of it. There’s nothing wrong with the plastic strainers, I just feel better with a brass “Y” strainer. We have one water feed supplying water to 3 of our Hydrominders on the chemical tank.
That's why I put a 1" whole house filter on the line. As long as it doesn't freeze, they don't fail. We had one wash where the distribution tube in one of the softeners split - you can imagine the many hours of cleaning resin and gravel out of the pumps and valves it saved me.
