Shouldn’t this thread be a “Sticky”!!!!????
Only if we want it to never be looked at again
I am planning on ripping out some boilers pretty soon too. I have done several tankless setups in the past. However, on these next ones, I am planning on using one tankless 400Kbtuh unit to feed hot pressurized water to a gravity tank. Then have one 400kbtuh tankless heater set up in recirculation mode to the gravity tank to keep it hot. The gravity tank will primarily fill with hot water, but I will have a lower float in the tank that will fill with cold water when the system demand is too much for the first heater. The t-stat for the recirc pump will be set about 5 degrees less than the fill tankless water heater will output, so the 2nd heater will only have to come on to 'keep hot' or to heat cold water coming into the tank during high demand. While this setup isn't new for me, the next part will be: I plan on ripping out the floor heat boilers (I really need the space) and installing a heat exchanger instead of the boiler. The heat exchanger will just be ran inline with the recirculation water heater. My only concern is that if the place looses power for a period of time during extreme cold, then starts up with below freezing glycol pumping through the exchanger - I may end up freezing the water side of the heat exchanger doing some serious damage. I may have to have some temp sensor that will protect this from happening and have to be manually ran til the glycol heats up some.... We will see how it goes. This should save some bucks. I will be taking out 2 million btuh worth of heaters to do the same job with 800kbtu. I hate seeing the 1.5 million btu boiler firing up for 4 seconds to heat up a 25 gallon tank 5 degrees when one customer is using a bay. What a stupid set up.
MJ, My concern was that if the system somehow turned on when it was off for a long time (like if power was lost when below 0 out) and then came back on, the temperature of the incoming glycol would be cold enough to freeze the water side and damage the units... While I can work around this, it would be good peace of mind to know that freezing may not cause any damage. I wonder how in the world a water pipe could be freeze tolerant...? hmm.
So what is the purpose of using them in your application? Reason I ask is that at one location that is a 6+1, we are making a new laundromat (the building was originally constructed to be one 20 years ago - but the owner decided last minute to put in a tanning salon). Was it that you needed different temperatures for each application (but you could use a mixing valve for that...)? I may be looking into doing something creative for the laundromat, as it will be packed with washers and have very little space for an "equipment room".
2Biz....I love your setup.
In studying tankless hydronic heating....I found a website that raised concerns about reliability. It seems some contractors have had problems since most units were NOT made for a 50% duty cycle.
Although my old RayPaks send 20+% up the stack.....they are indeed RELIABLE. It wouldn't take much to have my floor heat go out on a crazy winter weekend and ruin the cost savings from an efficient system.
How do you feel about reliability?
Also...
Here in PA, I'm told that ASME is required when used in a hydronic system. With Domestic Hot Water....not so as long as the input is less than 200K BTU's. I also have been told (does anyone know for sure?), that daisy chaining 199K BTU units does NOT trigger the ASME requirement.
When does the ASME requirement take hold? I'd hate to have a sweet system like 2Biz's....and then be told to rip it out because it doesn't meet code.
Also...
