Bubbles Galore
My wash is in desperate need of a behind the scenes refurb job. I need to get a new trough constructed that will allow me to run my HP lines in SS tubing and my LP poly lines in a neat and orderly fashion. Size is somewhat of an issue because I don't want to have to continue to heat a trough that is now triple the size of the existing one (current trough is 6" x 6" of usable space after adding insulation and such). I have 4 bays to the north that I want to have set up in this configuration. It's a jumbled up mess with splices and such and I can't take it anymore...also what do you guys use for your manifolds? I found some good ones on McMaster Carr, but they can get pricey if I go with stainless steel.
Any advice or pictures of your setup would be greatly appreciated. FYI, my trough is fully exposed to the elements on the flat roof of my wash.
Thanks in advance!
Thanks in advance!
