Tunnel pre-rinse
John, I notice that prior to the top brush your preasoak arch, is it a hign alkaline? Also, is the foamer which is beyond the first set of wraparounds a low ph? Also, the high pressure, what type of equipment is needed in the back room to push it?
High PH followed by Low PH. Side blasters use a Wanner H-25 and the rinse uses a Wanner H-35.
Have you calculated your cost per car for these HP applications including water and electricity? I think my wheel blasters were about 10 cents per car, as was my top blaster.
I have well water and the side blasters use the reject from my R/O.
Washnshine, here are a couple of more videos of my side blasters and high pressure rinse.
[video=youtube;BaCfpDPfoag]https://www.youtube.com/watch?v=BaCfpDPfoag[/video]
Hi Jon,
The side blasters shown in this video are great. I read one of your posts that you mentioned that you built it. Could you Please tell me how to build it with which height and material.
I currently have a hi pressure ossilating lower pressure rocker pressure from Hanna that I hate.
My back room has a Hydra Cell 25X and 10Hp motor that I can hook it up to it.
Also, on the last video I noticed that you have a top high pressure nozzles, side nozzles and a rim spinner. Do all 3 operate on 1 pump?
Thanks!
For the side blasters I use an H-25 pumping station that is 20gpm @ 800psi. In the bay I used a couple of old stantions from a set of rocker panel brushes and made manifolds out of 304 stainless pipe. There are 3, 3gpm nozzles on each side. The HP rinse is pwered by an H-35 pumping station rated at 35gpm@800 psi.
Thank you very much for the info! How long is the length in height for the stainless steel pipe for the side blasters?
