Vacuum nozzles falling off
Dirt Buster
What do you all do to keep vacuum nozzles attached to hoses? If i do nothing, customers pull too hard and take them off the vacuum hose. So for years we have used duct tape and taped the nozzles to the hoses. But after 2 weeks the duct tape gets kinda nasty. Any suggestions??
DavidM
PA
We use a hose cuff to connect the nozzle to the hose. They occasionally unscrew from the hose so we use a short stainless steel screw through the cuff into the hose.
David
Dirt Buster
David
Awesome idea. My hose end should be 1.5 inches. Do you use a 1.5 inch cuff?
Dirt Buster
We use this Gray 2” swivel cuff
https://www.kleen-ritecorp.com/p-825-vac-swivel-cuff-gray-2-in-hose-x-2-in-nozzle.aspx
and this Black Plastic Claw Style Vacuum Nozzle
https://www.kleen-ritecorp.com/p-580-mr-nozzle-2-in-black-plastic-claw-style-vacuum-nozzle.aspx
We don’t have a problem with them falling off, customers will take them off.
One of the out of town car washes we this https://www.kleen-ritecorp.com/p-831-vac-upholstery-cuff-2-hose-x-1-1-2.aspx
Great, thank you very much!
I thought 'seasoned' operators just jammed the nozzle in the hose and go?
I use a cuff and usually use silicone to lock the cuff on the hose or the customer will unscrew them off the end of the hose.
Greg_T
1 Licola Road, Heyfield, Victoria, Australia
Our hoses "screw" up into the vac head, then we use a heavy duty black tape which I find doesn't degrade over time. It's like duct tape, but matt black and seems to be much better quality. Not sure of the brand, just from our local hardware store.
