What's your monthly water usage/bill?
Ric
Cantree Member
West Michigan
I just got my record setting water bill for the first quarter of the year. 901,000 gallons used. $5700. I have a 5 & 1. Due to the cold weather the weep was running most of the quarter ( I do have a weep mizer).
How does that usage compare to yours?
WOW!!! Is part of the $5700 the Sewer bill also? My Water bill is in Cubic Feet not Gallons and it’s no where’s near that. $5700 cuts into the profit margin pretty hard.
borumrm
TN D&S 5000's
TN
just paid mine today...used 222,400 gallons last month....paid $2449.74
Water portion of that bill was 722.19, sales tax on that was 66.80 and the sewer charge was $1660.75
Have a 6 and 2 location. Oh yeah....as if this wasn't bad enough...we are charged a "stormwater" fee of $120 per quarter:eek:
Ric
Cantree Member
West Michigan
Yes, that includes sewer. Sewer is by far the majority of the bill. The $5700 is for 3 months.
Ric
Cantree Member
West Michigan
Sounds like we are pretty close.
My weep water really added up this season. I will look into an anti freeze purge system before next winter.
lag
Middle of Iowa
Hey Ric ,Hows it going? Do you weep your Auto? I have been running a Blowdown on our inverted L type automatics ,with very good results, for a number of years now. just a thought..
Buzzie8
Pittsburgh, PA
$4200 in January (water and sewage)
$3200 in February (water and sewage)
I will need to check the consumption.
Oh yeah, by the way, I have a reclaim system! Highest rates on the east coast as far as i know.
Robert2181
Midwest
I have some of the highest water and sewer rates over in Saginaw county,but I eliminated my weep system.
washnvac
Seaford, DE
Ric--that is only $6.33 per 1000 gallons used. That is not too bad. I have a location @ $10.50/1000, one @ $10/1000, and one @$9.85/1000. Look for water and sewer rates to continue upward, as municipalities are squeezed for funds.
Ric
Cantree Member
West Michigan
Lag,
Doing good. Tell me more about what you are doing with the blow down. I must put something into place before next winter.
I would think it is cheaper to add doors and heat to a automatic bay compared to weeping water through it all the time. My most expensive location for water and sewer is about 25% less than the original post. I have 3 other locations that are 50% less.
lag
Middle of Iowa
The blowdown is triggered by temp falling. When temp is low it will purge after each wash unless another wash is triggered. I have in the past had 3 relays , and 2 timers for controls. I now use a plc. I also have a fill system on the underbody so the pipes will have water in it when the UB comes on. I also had to add a couple of check valves.
We do have bigger compressors to operate them. your compressor should be able to hold at 150 psi with a 1/2 inch solenoid open for 30-40 seconds.
I would be happy to speak to you about the blowdowns if you thought it could help you out.
