copperglobe
JBS Power Concentrates or Kleen-Rite Ultra Concentrates? I've been using the KR versions for years but just wondering....
Do you mix the JBS like the KR? IE: two gallons water per bucket and same hydrominder tip? Just wondering about ratios...
For some of us it's [playing the hand you are dealt. I have found that locations with a "Break Tank" or good street water pressure no pre mixing is needed. For an older location with fluctuating water pressure it was much easier to pre mix than pay for costly upgrades. It i s easy to control, quality when you deal with 5 Gallon buckets. 1 Bucket of concentrate - 2 of water. If you end up with 14 gallons instead of 15, yes that is a 7% difference but in the whole scheme of things it's nominal since that gets diluted 100 to one or better, so your quality is of by 7/100s of a percent.Any time I see where people have to manually mix a product with water and then put it online, red flags go up..
Meaning IBA vs Foam Brush vs HP soap, or Dosatron vs Hydrominders, or flo jets and variable speed pumps. need more info.Does these concentrates work different with different types of equipment?
What size tip are you using for the Fonic as your hp soap?With JBS you can do it either way, mixing a 5 gal. Fonic with 10 gals. water and increase tip size to what you like or you can draw directly from the 5 gals.
I draw directly from the 5 gal. with their wax, presoak, tire clean and triple foam.
I’ve done it both ways with the Fonic and they both work great.
I just like to walk into the equipment room and seeing a 30 gal. filled up.
Old habits are hard to change, lol.
Any time I see where people have to manually mix a product with water and then put it online, red flags go up. For crying out loud, that is the way operators did this 40 years ago. Don't ask me how I know that. Just seems dumb to me. When you mix something on site there basically is no quality control.
I don't think, I KNOW, you're ceazy. But, when you're a billion dollar operator, you don't have to save money!I 300% agree with you Mac I cringe reading this also & I like all yall lol. Good quality chemicals you will not have to do this ever. I swear I am the only person that discriminates against kleen rite soaps and JBS y'all probably think I am crazy.
