We purchased the XRS doors with a new IBA we installed a year ago. Approximately 11 months after the installation, we have run into an occasional issue with the exit door which has created a major problem. After the wash package has been completed the exit door begins to open about 30 inches and stop. The VFD populates the error "F.PF" which is a motor overload fault. When this error occurs, the stop is always going up and it stops in the exact same position.
We have been working with both Airlift & our distributor to resolve this issue. To date, we have replaced the open & close relays, VFD, motor, the complete control box (including terminal strips, power supply, relays, VFD a 2nd time, etc.), the wire from the terminal strip to the motor, and the gearbox & motor (motor a second time). The mechanical side of the door appears to be in alignment and the hardware still looks new.
There is no rhyme or reason as to why the door fault occurs. One time, I manually put up the door by selecting the open button and the door did error, therefore in my view, it is not an issue with any of the wash packages. Obviously, during the cold & busy winter months, stranded vehicles in the bay plus long lines create issues that I don't need to describe.
My hunch is that the door may be binding, but I don't know what that would be on. Is there anyone out there in the car wash world that has any suggestions on what could be causing this issue?
