Air logic or Air shammee
Nick007
Hello,
I was wondering if someone can tell me the length of the boom? I need only the size of the metal pipe(see the picture).
Thank you in advance!
Nick007
In 2018, I went with Diskin's Air Shammee II, that has 1 - 4.5HP motor, mounted on my 5 bay walls. Our dryers get a lot of use. $10k investment was paid off in 3 months (per hour meters). Over the past 4 years we have improved their system as we found flaws... It might be over-kill but it's eliminated complaints from customers and increased customer satisfaction!
  • Added SS elbow (from Mosmatic) because hose clamp was cutting into the hose.
  • Added plastic vacuum cuffs to the elbow with self-tapping screws to help the hose stay on the boom elbow
  • Upgraded the hose clamps on the hoses. The original ones weren't strong enough to tighten around plastic corrugated dryer hose.
  • Added in-line swivel (Mosmatic)on the boom plate because short hose would kink when the boom was used.
  • Replaced their nozzle with Air Logics nozzle. Diskin's nozzle has an inner baffle that restricts the air flow & the back pressure caused a lot of problems (holes in hoses, hoses blowing off the end of the boom, rivets falling out of the nozzle). Also, customers didn't like holding the trigger while using.
  • Upgraded their sign with liability risk due to higher air speed.
  • Remounted the boom bracket through the concrete bay wall using 10" bolts, to support the added weight and welded the boom sections together.
  • Added 3' boom extension (from Mosmatic) to reduce stress on the dryer hose & better reach over customers vehicle.
  • Upgraded wand holder
If you want to see photos or more information, please send me a message. My photos are too large to upload here. I'm HAPPY to share!
Hi Kimberly,
Thank you so much for the info. I am considering putting dryers in my bays and now I’m in the research phase J
I think I understood most of your upgrades but I will ask, just in case. Sorry for been so explicit...
1. So, first you have the 3-phase motor.
2. Then, originally you have a black cuff(which I don’t think is swivel neither sides) with two clamps, that connects the motor with the short hose, right?
3. Then is the short hose itself. I think you’ve mentioned that you changed the hoses as well?
4. Then you have the plastic swivel cuffs, part #VAA-5?
5. Then you’ve put the swivel from Mosmatic (BOMP60323). It’s function is to prevent the short hose from twisting when customer moves the boom, right?
6. Then you have the boom with the extension and the metal elbow.
7. Then you have the VAA-5 again?
8. Then you have the long hose.
9. And lastly you have the Air Logic gun, no swivel in the cuff and you mount it with glue?
I have a few more questions, if anybody can help me with:
Aren’t both the Diskin and Air Logic hand guns have very concentrated air streams? It appears to me that it will take forever to dry up the whole car. Is anyone used the Mosmatic nozzle which is pretty wide compared to the ones mentioned above?
Are the 3-phase motors very loud and do they generate a lot of heat? I am asking because I have to mount a dryer in an underground parking lot.
Is anyone mounted an Air Shamme boom on the ceiling? In one of my bays the boom can’t be mounted on the wall. Mosmatic have a ceiling boom but they are pricey and I am not sure you can use the Mosmatic boom with the Air Shamme motor?
Kimberly Berg
Citrus Heights CA
Hi Kimberly,
1. So, first you have the 3-phase motor. YES
2. Then, originally you have a black cuff(which I don’t think is swivel neither sides) with two clamps, that connects the motor with the short hose, right? DISKIN PROVIDES THE RUBBER CUFFS FOR THE SHORT HOSE THAT GOES FROM MOTOR TO THE BOOM.
3. Then is the short hose itself. I think you’ve mentioned that you changed the hoses as well? YES, ORIGINALLY THEY WERE INSTALLED WITH A SECTION OF STANDARD VACUUM HOSE, BUT WITH THE BACK-PRESSURE FROM THE ORIGINAL DISKIN GUNS, THEY WERE SPLITTING. WE NOW USE A RIGID, HEAT-RESISTANT HOSE FROM KLEEN-RITE (NOT A VACUUM HOSE).
4. Then you have the plastic swivel cuffs, part #VAA-5? NO, WE ONLY USE ONE VAA-5 CUFF AT THE END OF THE BOOM ELBOW.
5. Then you’ve put the swivel from Mosmatic (BOMP60323). It’s function is to prevent the short hose from twisting when customer moves the boom, right? YES, CORRECT. WITHOUT THE INLINE COUPLING, THE HOSE WAS PINCHING CLOSED WHEN THE CUSTOMER MOVED THE BOOM (CUTTING OFF AIR FLOW).
6. Then you have the boom with the extension and the metal elbow. YES. MOSMATIC BRAND EXTENSION AND METAL ELBOW.
7. Then you have the VAA-5 again? WE USE ONLY 1 VAA-5. WE HAVE TRIED BOTH VAA-5 AND THE VAS22P. THE VAA-5 IS 1 PIECE CUFF (SLIP ON ONE END AND THREADED ON THE OTHER. YOU CAN QUICKLY SCREW THE VACUUM HOSE INTO THE THREADED END (SECURE WITH 4 SELF-TAPPING SCREWS), THEN SLIP THE OTHER END ONTO THE METAL ELBOW WITH A HOSE CLAMP. IF YOU NEED MORE RIGIDITY FOR THE SELF-TAPPING SCREWS, YOU CAN ALSO USE CUFF (VAS22P). IT HAS AN INTERNAL SWIVEL NUT. WE USED THESE CUFFS WHEN WE FOUND THAT HOSES WERE FALLING DOWN IN THE BAYS, FROM CUSTOMERS PULLING ON THEM.
8. Then you have the long hose. WE USE STANDARD 15' KLEEN-RITE VACUUM HOSE. THEY HAVE MORE UV PROTECTION AND HOLD UP BETTER TO HEAT AND SUNLIGHT.
9. And lastly you have the Air Logic gun, no swivel in the cuff and you mount it with glue? WE USE AIR LOGIC GUN, NOW WITH THE SWIVEL. NO GLUE NEEDED. SCREW THE VACUUM HOSE INTO THE THREADED GUN, SECURE WITH 3" LONG SCREW AND ROUNDED CAP NUT.
ALTHOUGH THE AIR FLOW OPENING ON THE AIR LOGIC GUN IS ONLY ABOUT 1.5", WHEN IT COMES OUT 300MPG, IT DRYS A WIDE AREA OF THE CAR. THE DISKIN GUN IS A BAD DESIGN. IT HAS AN INTERNAL BAFFLE THAT IMPEDES THE AIR FLOW, CREATES BACK-PRESSURE AND HEATED TURBULENCE, WHICH IS WHY WE SWITCHED TO THE AIR LOGIC GUND. NO MORE COMPLAINTS FROM CUSTOMERS.
Are the 3-phase motors very loud and do they generate a lot of heat? I am asking because I have to mount a dryer in an underground parking lot. I DON'T KNOW THE DECIBELS OF THE DISKIN. IN A CONFINED AREA, THE SOUND WILL PROBABLY MAGNIFY. BUY 1 AND TRY IT OUT.
BY SWITCHING FROM DISKIN TO AIR LOGIC GUNS, IT HAS ELIMINATED HEATED TURBULENCE. THE AIR FLOW DOES GET WARM FROM THE BLADES MOVING ON THE MOTOR, BUT IT'S HOT. IT HELPS DRY THE VEHICLE.
Hi Nick007,
Since we installed the Diskin 3-phase dryers in the bays, we've tried many different things to improve customer experience and air flow. I've added the updates after your questions above (IN CAPS).
Please let me know if you have any further questions!
Kimberly
Yes, fairly concentrated but if you use a good sealer/Rain-X type product/ceramic or even a wax first it only takes maybe four minutes to get a small car 90% dry. If you want it truly dry then it will take a really long time. You should try to find a wash that has them and try it for yourself.
The three phase motors/producers are very quiet. I'm not sure exactly how hot they get but it is not something that should be of concern.
Nick007
Hi Nick007,
Kimberly
Thank you so much for your detailed response. Everything is much clearer now. Only the ceiling mounting is kind of a stretch but I'll figure it out.
Nick007
Thank you OurTown!
