Now, After you’ve had time to digest all that, I’ve offered you two options. If you settle on a Demand heater and keeping you holding tank, Your looking at about $3,000 for the install…
$1500 for 199K BTU Condensing Demand Heater
$600 for Taco 2400-50S S.S Circulation Pump
Another $900 for T-stat, 1” copper tubing, wiring, relay for pump, box for relay, intake and exhaust venting, service ports (To clean boiler scale) shut-off flanges for pump, etc., etc.
Plus time to do the install?
OR
I’m wondering if you looked at my other suggestion? Post 16? You can also compare the link in this post to a Polaris PGC3 50-199-3NV which is another tank style water heater, It has a recovery rate of 426 gph @ 60° temperature rise. These two units are condensing tank style heaters (High efficiency) that have almost “NO” head pressure through the heater. You would simply replace your existing holding tank and forgo all the extra plumbing, pumps, relays, and wiring…You simply hook it up to city water. For about a $1000 more… How much is your time worth? If I were to replace my (not working 350K Jarco Boiler) I would seriously consider one of these or similar….
OR
