I don’t understand why you guy’s keep fighting with these gravity fed tanks. The simplest solution is to put a Generant regulator on the water inlet, a DEMA injector and feed the pump with reduced city water pressure, Hot and Cold. They aren’t a big maintenance item, in 32 years I think I’ve replaced 3 or 4 regulators, never touched the injectors. No more Float valves, no more over flowing tanks, no check valves, I’ve never had a washed out Cat 310 pump head. The pumps run quieter because they aren’t working as hard to draw suction.
Randy,
You might have already told me, but how are you switching between hot and cold water?
