I need some help on wiring a lp panel. I’ve never done this before. Attached are some picture from the wash. Do I have to do anything with the switches?
The regulators can take 150 PSI inlet despite what the manual says, but I always put a regulator on the compressor and set it to 90 so if one on the system fails and lets too much pressure through tings are protected from damage. As long as the pressure is the same or a bit higher than your highest setting on the other systems, nothing will be affected.One other question, the installation manual say air pressure going to the board should be less that 100 pounds. Mine is currently set around 140. Can I just turn the pressure down on the air compressor without it affecting the flo jets for my current low pressure functions?
If you don't already have something on the compressor, you might consider a filter with an oil and water separator too, or a regulator with those on it. Flojets don't like oil or water in the air.No spot free right now. That’ll be my next addition. I’m going to take your advice and just install a regulator coming out of the compressor and run all my low pressure functions through it!
I just need some clarification just make sure I'm doing things correctly. My 24v hot wire that runs to the new panel is going to come off the left side of my terminal pictured above? For instance, Ill run a wire out of the left side of #9 in the terminal to the corresponding hot terminal on the air logic panel? Then ill run the common wire out of slot #2 on the terminal to the common terminal on the air logic panel?
So they are assuming all of your bay commons are tied together for this to work...Can you verify? In order to connect all bay transformer "Commons" together, its a good idea to have all the bay transformers phased the same.
Looking at an Air Logic System, it consists of a Flojet and a bank of chemical solenoids and a bank of air solenoids where each bay (Air and Chemical) solenoids are connected together. I see only (1) common terminal on the strip.....So they are assuming all of your bay commons are tied together for this to work...Can you verify? In order to connect all bay transformer "Commons" together, its a good idea to have all the bay transformers phased the same.
Is it possible to move or change the transformer inputs to different positions to get them in phase with each other?
