A couple of things to note about the RO pre-filter. (This applies to all brands and makes.)
Filter type: Most of the filters on car wash ROs are usually 2.5" diameter x 20" length, 2.5"x 10", or 4.5"x10" (often called Big Blue). Regardless of the size, you should always use a melt-blown type filter and they are typically made from polypropylene. NEVER use a pleated filter when there is a pump downstream. If the filter becomes clogged, the pleated filter can collapse and get sucked into the pump causing major damage. Stringwound filters are also not advised.
Pore size: 5 micron is the best overall pore size, although some units are built with two filters in series and are designed to have a 5 micron first and then a 1 micron. This is an ideal setup but most of the time on city water pressure there's too much of a pressure drop across a 1 micron filter. If you have this, just leave one filter canister (called a sump) empty and put a 5 micron in the other.
Changing frequency: Please just change these once a month, they are cheap insurance. You can get them shipped from
Kleen-Rite for a couple bucks each. Some people will say change it when there is a 10 PSI delta, and this is good advice, but 99% of car washes don't have pressure gauges on both sides of the pre-filter (or at all). If the filter is dirty when you change it, you waited too long.
Other pre-treatment:
In addition to the pre-filter, all ROs are designed to be fed softened and de-chlorinated water. Hardness should always be less than 1 GPG (ideally 0-5 PPM) and free chlorine should be less than 0.2 PPM (ideally 0 PPM). Chloramines generally do not damage an RO membrane if the pH is in normal range but they can over time. RO membranes are expensive but if you take care of them, they will last for many years. If you don't, they will not.
A 5 micron filter is designed to catch anything larger than 0.00019685 inches in size, so just because it looks "clean" doesn't mean it's not full and done it's job. Your RO inlet water should be going through a carbon bed first, which can act like a 5 micron filter itself. The filter is there to catch anything that makes it through the carbon bed and also broken down carbon from the bed. For reference, the pore size of an RO membrane is roughly 0.0001 and 0.001 microns. This is so that only some of the water molecules (H2O) can get through and the rest goes down the drain along with all the dissolved solids (TDS). This is obviously a perfect scenario and not every pore size is within spec so some dissolved solids always get through. If you are showing 0 TDS on your permeate (product water) then your meter is wrong.
