Rytec Wyndstar Issue
JGinther
Zip-tie engineer
Loveland, CO
There is no risk in connecting or disconnecting the red and white wire. That is exactly what the limit switch is doing.
You would use a voltmeter to measure the signal output of the sensor. Meter on dc, black lead on 0vdc, red lead on the black wire from the receiver.
SparklesSS
0vdc as in grounding it?
JGinther
Zip-tie engineer
Loveland, CO
No. As in put the black lead from the meter on 0vdc. Don't ground anything! I just looked back and you labeled it 24vdc- which means the same thing. So put the black lead on the wires from the orange wire nut in the pic.
SparklesSS
thank you for your help!
SparklesSS
Red Wire was loose and not sending the signal. Thank you for your help!
Appears I have not been successful in finding the solution. Photo eye stopped working again today. Yesterday I check it out and there was a delay between when I broken the photo eye "beam path" and when the door went back up. After doing this a few times it became quicker. Today I went there and it was not working at all. I popped off the motor cover and checked the connections to the photo eye and limit switch. all seemed good. I connected the two wires at the limit switch (red and white) but this did not help. The door would open but the stop or close controls would not work. Any suggestions?
SparklesSS
SparklesSS
Check the red and white wire first.....both open and shorted. I bet that's your problem.
JGinther
Zip-tie engineer
Loveland, CO
What happens when you have the red or white wire off? Do you know how to set the limits? That one should be set to allow they eye to work until the door is at the level of the eye. Then the signal will be bypassed by the limit switch (eye will then be ignored until door is above eye level again.)
SparklesSS
Think I finally figured it out. 24v steady from the black wire coming from the emitter into terminal 5. When the receiver drops voltage the emitter maintains it so the limit switch doesn’t activate. Removed the black emitter wire from terminal 5 and all seems to be good. Will keep you updated if anything changes. Thanks again!
JGinther
Zip-tie engineer
Loveland, CO
There should be no connection in the emitter for the black wire... Only in the receiver. Not sure how you would be getting voltage from the emitter when it's not supposed to be connected. It's a good plan to keep those separate anyway... I'm not sure why rytec would have wiring diagrams showing them wired together... Probably trying to 'keep things simple'. That should not have been the cause of your problem... Lol.
SparklesSS
I was surprised to find voltage in that line....could be on its way out.
Rudy
Pennsylvania
If the bypass microswitch is NOT making a good connection between the red and white wire....the photo cell amplifier will be receiving a "weak" signal. Connect the red and white wires with a good jumper. See what happens. Again, I bet there's a good chance the photo eye system will shows signs of better reliability. If so...the problem rests in a failing microswitch.
Jumper it...and report back.
SparklesSS
Tested that and it made no difference. Think I finally figured it out. 24v steady from the black wire coming from the emitter into terminal 5. When the receiver drops voltage the emitter maintains it so the limit switch doesn’t activate. Removed the black emitter wire from terminal 5 and all seems to be good. Probably why nothing changes when I bypassed the micro. Will keep you updated if anything changes. Thanks again!
Samm
Where do the grey wires in the nut go? Are they the third wire in the cable going to the sensors? Are you sure you have the correct sensors? They need to be PNP type for Windstar doors I'm pretty sure. Trying to judge by the pictures, it appears the limit would be the grey cam that has the red and white wire connected - above the board. If its wired how they meant for it to work, it would be like this:
Both (emitter and receiver - even though only receiver wire is actually functional) signal wires from the sensors (not blue, not brown - those are power) would wire to the cam switch. The cam would be adjusted so that it would allow the signal to the board when door is up and keep allowing it through travel down until the door reaches the sensor elevation. At that point, the cam would bypass the signal and the door would continue to close even if the eye was to be blocked. Its dumb.
Can I call you please?
Samm
I can't tell from your picture. It looks like you have 4 limit switches. I'd bet that only 3 are wired (or in use). Trace the wires back to the end of the board. There's a 7 contact strip (abeam the 2 blue adjustable resistors). The left (first) contact is for close, the second is for open....and the third is the common. The wire from the first should track to the close limit switch, the second wire should track back to the open limit switch. The remaining limit switch should be the bypass one.
Am I correct that only 3 limit switches are wired?
Can you call me please at 313-377-7015
Samm
My problem is: When the wash bay is activated, the door opens then it does not close after a vehicle enters. When you push the button to close it & block the eye, the door stops in its place and does not reverse.
SparklesSS
[/QUOTE
Do you have door controller buttons in the bay? Maybe one of the contacts is frozen?
check the photo eyes. Is there a light on each side? One is on the side one is underneath.
