We changed all our CryptoPay swipe to Tap Plus. Easier to use and more reliable. Customers seem to get it too. Having the button separate from the device also seems to help the process....
The only conflict I would've been worried about is that the TapPlus and the swiper both transmit a signal where the CryptoTap uses the swiper to transmit.I added tap plus to all mine and kept the swipers. Tap usage is already at 50% + via the portal reporting. I still see customers swipe that have chip cards, so I like having both. Didn't see a reason to remove the swipe if it still works. I use the button on the swiper to end the charges. This is something that was not possible until a few months ago, so maybe that's why others removed the swiper. I drilled 3 holes for the tap plus and that was it. No extra hole for the large button.
TapPlus or add-on tap too?Note. If a customer uses tap on say a bay and swipe on something else like a vac or just does it a different way for a second transaction CryptoPay treats them as separate transactions since one is a EMV transaction. Recently learned about that undocumented feature. Minor but does increase transaction costs in that situation.
Any tap.TapPlus or add-on tap too?
Solution is to have same model all over site? (no mixing of models)
Good to know.
I have swipers and LED 9 timers.If I keep the swipers and add the TapPlus do I connect the Red/Green wires to the same timer terminal?I added tap plus to all mine and kept the swipers. Tap usage is already at 50% + via the portal reporting. I still see customers swipe that have chip cards, so I like having both. Didn't see a reason to remove the swipe if it still works. I use the button on the swiper to end the charges. This is something that was not possible until a few months ago, so maybe that's why others removed the swiper. I drilled 3 holes for the tap plus and that was it. No extra hole for the large button.
Call CryptoPay tech support. The configuration you mention they refer to is called the side car configuration. They can help you wire it so the swiper button turns off both devices.I have swipers and LED 9 timers.If I keep the swipers and add the TapPlus do I connect the Red/Green wires to the same timer terminal?
Additionally how is the swiper switch configured to work with the TapPlus?
I'm pretty sure I just had to connect the power and common wires for the tap plus. Then you have to chat with support and provide them the device ID of the tap plus and the swiper and they can combine the two so that they work together. Then you push the swiper button to end the transaction and no separate button needed.I have swipers and LED 9 timers.If I keep the swipers and add the TapPlus do I connect the Red/Green wires to the same timer terminal?
Nayax does, one of the big reasons we used them. Mobile phone/ smart watch payment users are constantly increasingWe are getting more request to accept ApplePay….?
Does the plus accept Apple, or is that another proprietary component needed…?
